TractorLinks.com
Show Parts for Model:
Re: How to buy a rebuilt motor update 2- question
upnorthwi
12-18-2012 16:01:36
That is an interesting idea, never heard that one before, but it makes some sense.
But here's a question,
If a motor is stuck from rusted cylinders and rings and you break it free, aren't you then taking all that rust and scoring the cylinders to the point of being an oil burner?
I guess that confuses me, I hear the stories on the ones that sat in the field, they free them up and they run, but it seems like all the moisture..rust would tear everything up.
Or do you break them free to help you tear them apart? Can they still be usable after being freed?
What do you think of the idea of using air pressure?
I read to avoid anything or force that might bend the rods, but it seems there isn't much of a choice.
I think mine was already stuck when they put the head back on. It's either a bad head that leaked and rusted or however long it sat without the head before he put it on. He said there was some rust, but no idea how bad it was. I'm thinking real bad.
Jason S.
12-18-2012 16:58:29
 Re: How to buy a rebuilt motor update 2- question in reply to upnorthwi, 12-18-2012 16:01:36
When it breaks loose the rings will scrape a lot of the rust off of the walls and push it to the top of the cylinder where it can be wiped out if the head is off. I usually take a cylinder hone and hone the tops of the cylinder walls so it removes some of the rust before i try to break it loose.Will it be an oil burner? That depends on how bad the cylinder walls are pitted and the rings are worn. If I could break it loose and crank it that"s what I would do. That way you can check oil pressure, listen for knocks, check the hydraulics and etc...
Jason S.
12-18-2012 17:10:23
 Re: How to buy a rebuilt motor update 2- question in reply to Jason S., 12-18-2012 16:58:29
I've never tried air pressure, I've even heard of people pumping the cylinders full of grease and the hydraulic pressure breaking them loose but I would not ever try that. Personally I would remove the head and soak the cylinders some more and then take a block of wood and a hammer and tap on the tops of the pistons. Then take a breaker bar and socket and put on the bolt on the crankshaft pulley and see if it moves any. If it doesn't repeat the process. Just keep working at it. I don't rock the tractors when the engine it stuck because a lot of the time the clutch will slip before it break the engine loose. Especially if the clutch is worn.
