Jeremy in DE
I am looking for the cause of my oil pressure loss when hot. I pulled the oil pump and found all the screws have damaged heads. I cannot turn them. Did a previous owner try, fail, and leave them this way?
What should I try?
Related. After pulling this off I tried to remove the bearing cap so I could check the clearance. That cap doesn't want to come off. Before I damage anything, is there something I'm missing.
Middle bearing, about .003. Rod bearings all between .0015 and .0025. Haven't checked rear main yet.
What should I try?
