Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TO30 lift question
Jason S.
12-13-2012 09:14:31
Yes.If the draft spring is out of adjustment it will change how the lift operates.The correct procedure for the draft spring is to hook up an implement...they recomended a 2 bottom plow but a box blade will do, and with it fully raised you should about .020 clearance between the end of the spring and the plunger.If you dont have a feeler gauge you should just be able to turn the spring by hand when the implement is raised.But, be forewarned that more than likely the plunger will not turn unless it is heated cherry red to break all the years of rust loose.If you try to adjust it and it wont move and you dont heat it, you could bend the fork inside, the control valve can come unhooked and etc. After you adjust the draft spring then adjust the quadrant again. Because when you adjust the draft spring it will change the adjustment of the quadrant.
