| Harry Ferguson Tractors Discussion Forum |
Topic: To30 high low range?
[Return to Forum]
| Author |
[Modern View]
| MikeAC
12-11-2012 10:48:32
64.121.81.44
Anyone familiar with a high/low shifter on a to30? Would give 8 forward speeds, it does not pull out laterally. I have some pictures here, |
[Reply] [No Email] | |
| Dean
12-12-2012 12:54:27
152.216.3.5
Re: To30 high low range? in reply to MikeAC, 12-11-2012 10:48:32
| | The link is inaccessable from my location but (asuming that the shifter is on the left) your Sherman is a step up (only) if the shifter handle is steel with an aluminum ball. If the shifter is one piece cast iron it is almost certainly a combination (UD/Direct/OD), though it could possibly be the very uncommon UD only. Dean |
| Bruce(OR)
12-11-2012 17:12:41
97.115.29.130
| I'll jump in the middle. Looks like a combo handle. In neutral it should pull out. I would cheat and grab a pry bar and try some gently persuasion. Top gear was for road speed to get you down to the next pasture asap. Still needs a Howard for tilling properly. |
| s19438
12-11-2012 12:09:45
108.36.215.99
| looks like the one on my 9N. step up only me thinks. |
| Tony C.
12-12-2012 06:48:41
69.127.139.162
Re: To30 high low range? in reply to s19438, 12-11-2012 12:09:45
| Weren't there also some on the N's that were step-down only? That is what I have mostly seen in our area when they come up for sale(vegetable farms). |
| Dean
12-12-2012 12:51:07
152.216.3.5
Re: To30 high low range? in reply to Tony C., 12-12-2012 06:48:41
| | Yes, but step downs are VERY uncommon. Dean |
| MikeAC
12-11-2012 12:29:55
64.121.81.44
| That's the way it seems to work. I was hoping it was the combination. The lever looks like it could have been. Don't know what you would use the faster speeds for. |
| Leroy
12-12-2012 18:49:48
69.88.205.38
Re: To30 high low range? in reply to MikeAC, 12-11-2012 12:29:55
| Well use 1st under like on a transplanter, then 2nd is normal plowing but when get to a tough spot go to 2nd low and if you got to easy going then shift to 2nd high, 3rd low good for disking in previously worked ground, straight 3rd for disking in unworked ground, 3rd over for a hay rake or spring tooth harrow, 4th under for the rotary hoe, 4th for road travel with heavy loads going to local grain elevator but on way home with empty wagon then 4th over so you made it home before dark. 3rd over also good for going out to field with manure spreader. Doubles use out of that tractor with using less fuel if you have the gears you can shift to with a lower engine rpm and also less engine ware. MY TO30 did not have either one and sure wished it did. Would have made a big difference in time to haul a 20 mile round trip to the elevator. Both my 9N & 2N Fords have the over and wish they were the combination. The NAA Ford did not have one as well. |
| Richard L
12-11-2012 17:10:46
71.90.139.15
| That is the same lever we had on our TO 30 and I never knew about a combination until maybe 4 years ago on this forum. |
| s19438
12-11-2012 15:11:04
108.36.215.99
| road travel ????? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
