I have a TO-20 that i bought but the distributor was on borrow and the seller had to return it.
In any event I bought the tractor minus 1 distributor.
I was able locate one , a TO-35 (used) for approx.
$100.00, new they sell for over $300.00 the
T0-35 is the same in length and gear size and the
professionals say it does work as a replacement
for the TO-20.
Today I installed it using the technique of
bringing number 1 cyld. to TDC and pointing the
rotor to same.
It started on the firs try, but was running a little rough I turned it in attempt to time it
correctly, however, it was not quite right.
I removed it and installed new points and rotor
NOTE: I wanted to make sure it would start with
this distributor before changing out the points and rotor.
Well upon my 2nd attempt installing the distributor it does not want to start.
QUESTION: Does anyone have a suggestion in the
proper installation of a distributor ?
I find myself 2nd guessing my installation
procedure.
ANY SUGGESTIONS WOULD BE APPRECIATED. thank you.
