Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1950 Ferguson TO20 has no spark
Rob Tholin
12-04-2012 19:24:08
As what was previous said the crank goes around twice to the dist.. Therefore the #1 could be up, but not on compression. Feel the air compression pushing out of hole #1 when turning crank by hand.
Stop when #1 is at full top height. Install dist. point at #1 on the cap. While your there check which way the rotor turns and check firing order. Is it backwards?
Next I have seen new points with a substance on the contacts. They should be cleaned- put a piece of paper in them when closed and pull it thru, this will clean them. Install cap & rotor. Crank engine with key ON. You should have spark at the coil wire.
If not put a test light on the points wire to the coil and the clip of the test light lead to the block. When cranking the light should flash. If not there is a problem with your primary circuit.
DILLON45
12-05-2012 15:26:57
 Re: 1950 Ferguson TO20 has no spark in reply to Rob Tholin, 12-04-2012 19:24:08
ROB,
You hit the nail on the head, there was a sticky film on the points.
Thank you.
Copyright © 1997-2015 Yesterday's Tractor Co.
