Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Front Axle Support Assy.
John(UK)
12-03-2012 03:44:27
The Pin MUST be a good fit in the holes in the Axle Carrier or it will be moving and throw some load onto the bolt that holds the pin into the Carrier. The holes for the pins will need building up and boring out again/ or find another axle carrier/ The welded plate does not need to be there, there is nothing complicated about the Pin mounting and it is just straight forward. Make sure that the pin cannot move in the axle carrier or it will wear the holes and gradually get worse and it will load up the securing bolt which will break and the pin will then come out and the tractor will drop and the front end and damage the Radiator and the Hood. You could weld some plates to reinforce the Carrier at the main pin holes, fit these on the inside of the carrier if you have room. Bore out these plates the same size as your new Pivot Pin, the loading will now be taken on the plates rather than on a worn axle carrier and you can bore the plates the correct size for the pin. Just be aware when fitting the plates that the center axle beam does not catch the plates when it is all assembled with the Radius Rods attached, it maybe that the plate you attach to the rear of the carrier may need to be thinner to give the necessary clearance. Don't lubricate the pin and bush with oil or grease, if you must use something then use graphite powder. If you would like the parts list that shows the different pins and Bushes, just ask by emailing me at the address below. If you can fit the heavier Bushes they would be better but if you have the old axle then you will have to fit the thin wall bush again.The heavy Bush will not fit into an axle beam that was originally fitted with the Thin Wall type as the hole in the Beam is smaller. While you are carrying out this work, remove the King Pins from the axle extensions and check the thrust bearing at the bottom of the King Pins as they are often running dry and are badly worn, this causes heavy steering.Ask if you need any more info John(UK)..fergusontractors@hotmail.com
