TractorLinks.com
Show Parts for Model:
Re: 1951 H. Ferguson
John(UK)
11-22-2012 07:33:40
It is possibly the Needle Valve above the Float that is sticking or the Float could be punctured and has fuel inside it and is now too heavy to float. You need to remove the Carburettor and check these parts and replace if necessary. You should also check just how high the fuel is rising in the carburettor before it is shut off by the float, it does look as though it isn't shutting off. If this is the problem and even if you shut the tap off each time you stop the engine, because of this problem it will always have the fuel level in the Carb higher than it should be and it will use more fuel.Even if you weaken the mixture to try to allow for this extra fuel, you will not be able to compensate for this, it will always be slightly out and never correct as it should be. If you want info about the carburettor and setting it, email me and I will send it....John(UK)....fergusontractors@hotmail.com
