Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: TO-30 won't start
[Return to Forum]
AH
11-19-2012 11:15:12
76.1.142.140
Just rebuilt a TO30 engine, carb, dist. new battery, I can't get it to start with battery. Pull 3 feet and it starts, but not with using battery, even while battery charger is connected. Seems to be turning fast enough. Any ideas. Any help appreciated.
[Reply]   [No Email]
Tony in Mass.
11-20-2012 16:23:57
76.127.225.182
 Re: TO-30 won't start in reply to AH, 11-19-2012 11:15:12
Sounds as if John is going to win the cigar. If your wiring was off, it wouldn't start no mater how the flywheel turned...but since it would rather start by turning the rear wheels than the starter motor... your bearings are still a little too tight. Next time you start it, let her run a while, no hard jobs, but don't just turn it off... and that might make re-starting even worse!
[Reply]  [No Email]
John(UK)
11-20-2012 08:19:25
79.76.255.252
If you have only just o/h the engine it may be tight and you may find that a little work will help to loosen it. Have you moved the ground lead from the back of the dash panel, attach it to one of the bolts close to the Starter. If you are using 6 volts, then make sure that you use the heavier cable for the starter and ground (Gage 0) not the thin cable like a 12 volt.Have you looked internally at the Starter, is it burnt or the brushes worn?...John(UK)...ferusontractors@hotmail.com
[Reply]  [No Email]
Bruce(OR)
11-19-2012 16:56:35
97.115.29.33
12V or 6V? Resistor bypass? Ign key to start or the shifter handle?
The wife"s TO-20 has the shift handle hooked to a Ford starter solenoid.
Your"s?
[Reply]  [No Email]
Jerry/MT
11-19-2012 12:18:09
206.183.116.145
Have you checked the spark? Is the timing and the firing order (1-3-4-2) correct?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
