Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: TO35 back in the family
[Return to Forum]
danderson
11-19-2012 11:01:02
64.198.120.49
After waiting a few years I finally was able to secure my grandfathers 1955 TO35, which I had driven many times as a teenager. I just picked her up from a small town mechanic who replaced all the engine/transmission seals, oil soaked clutch plate/throwout bearing, rebuilt the oil pump, and a number of minor issues I did not have time to fix. I did put on a rebuilt carb, a new 12 volt alternator with a rear drive, and replaced all the guages with my new tachmeter/cable coming this week. My mechanic commented about how much power she still had and was quite surprised. She's actually in very good shape and my next project will be to remove the liquid from the tires and repaint the rims. We were born in the same year so I better take care of her!
I find this forum quite useful, especially the resources. Because of double ordering I have 2 sets of the front end transmission/pto shaft seals PN's 195503M1, 195501M1. Let me know if anyone is interested.
Thanks
[Reply]   [No Email]
Jeff-oh
11-20-2012 08:23:30
69.174.58.132
Re: TO35 back in the family in reply to danderson, 11-19-2012 11:01:02
Just remember it is easier to find parts for an old tractor than an old man.
  [Reply]  [No Email]
danderson
11-21-2012 14:23:32
64.198.120.49
Re: TO35 back in the family in reply to Jeff-oh, 11-20-2012 08:23:30
After having an aorta replaced with a Gortex tube, I truly understand that comment!
  [Reply]  [No Email]
John_Mason
11-20-2012 07:54:29
68.41.49.190
I have a 55 TO35. I love it! Originally purchased by my boss's grandfather.
  [Reply]  [No Email]
2tractors
11-20-2012 05:14:56
207.144.5.133
The slight droop in the front bumper shows a worn front pivot pin, mine is much worse.
  [Reply]  [No Email]
John(UK)
11-20-2012 08:14:54
79.76.255.252
Re: TO35 back in the family in reply to 2tractors, 11-20-2012 05:14:56
When the Pivot Pin wears and you leave it, the next thing to go is the Radius Rods will bend up-wards in the middle as they are supporting the axle from twisting, then after that it will knock the bottom water hose connection from the radiator and if you don't notice this when working, the engine will seize up, this has happened on many occasions.. Replace the Pivot Pin and Bush or it will wear the axle too much and you will need another axle beam as well. When repaired the steering will be much lighter as well, you will think that you have power steering. Also check the bearings at the bottom of the King Pins as they don't get enough grease....John(UK)...fergusontractors@hotmail.com
  [Reply]  [No Email]
danderson
11-20-2012 14:40:18
64.198.120.49
Re: TO35 back in the family in reply to John(UK), 11-20-2012 08:14:54
John,
Since joining the forum I have enjoyed your insight. Regarding the Pivot Pin and bushing, I have a total parts diagram and assume it is part numbers 183221M11 for the bushing and 180344M12 for the pivot pin. They are inexpensive at around $45.00 for the set and don't seem too hard to replace. On the project list!
Cheers
  [Reply]  [No Email]
John(UK)
11-21-2012 04:45:42
79.76.249.235
Re: TO35 back in the family in reply to danderson, 11-20-2012 14:40:18
Thank you for your comments!
Make sure that you do get the correct parts as there is more than one type of Bush and the Pivot Pin is also peculiar to the Bush that is fitted. The Bushes originally were a thin wall type and the later ones had a thick wall with a collar on one edge. If you have this thick wall type, fit TWO not just one and it will give more support to the axle and prevent the load being transferred to the Radius Rods as it wears.The Axle beam is different depending on the bush fitted, the thick wall type has a larger hole in the Centre Axle Beam. If you need more information about this or anything else, email me direct at fergusontractors@hotmail.com....John(UK)
  [Reply]  [No Email]
maxwell99
11-19-2012 11:18:26
208.78.252.64
I still have my dad's TO-35.
it is a 1957 and was painted cream color when new. I later painted it red as everyone thought it was a old case of some type.
were you able to keep the tach operational when you changed over to the alternator?
mf did make a alternator with the gearbox drive for the tach a few years.
so far i have been able to get my old generator fixed and have keep the tach working.
good job on the paint work.
  [Reply]  [No Email]
danderson
11-19-2012 11:04:02
64.198.120.49
Photo didn't work, let's try again
  [Reply]  [No Email]
Ed H.-OH
11-20-2012 10:05:49
72.23.247.131
Re: TO35 back in the family in reply to danderson, 11-19-2012 11:04:02
Hello, I too was born in 55, and have a 55 green belly to35. Been a great tractor for 30+ years.
Good luck with your 35,Nice looking tractor!-ed
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
