| Harry Ferguson Tractors Discussion Forum |
Topic: MF 35 hydraulic/pto
[Return to Forum]
| Author |
[Modern View]
| three35's
11-18-2012 07:17:04
69.179.13.52
Just bought a MF 35. For the past many years the 3 pt arms have been removed an a front mounted snow plow has been run off a set of auxliary remotes of the top cover below the seat. Now there is no hydraulic fluid coming out of the remotes, the 3 pt arms are stuck in the up position, and no pto. This is a single stage clutch and the pto turns freely by hand when in both neutral and engine pto Are these all related, and where would I start checking first? Thank you |
| three35s
11-18-2012 17:43:29
69.179.13.52
Re: MF 35 hydraulic/pto in reply to three35's, 11-18-2012 07:17:04
| Thanks for your reply. My concern is that there is an internal problem with one of the grears that powers the hydraulic pump and then to the pto. Is this a possiblily? I plan on taking the inspection covers off and see if I can see the output shaft of the pump turning. If not, what would be my next step. If it does I will remove the top cover for more inspections. Does this make sense? |
| John(UK)
11-19-2012 05:20:01
79.76.255.179
Re: MF 35 hydraulic/pto in reply to three35s, 11-18-2012 17:43:29
| If you removed the Top Cover you could see if it was driving but that is all,you would be better to split the tractor first as last if you think that it isn't driving the Pump as that is what will need to be done anyway, so no use making a big job any bigger. You are better leaving the hydraulics alone unless there is no other option.Unusual for no drive to Pump, this could be something at the front end of the transmission. If you need the info about this email me at the address below and I will send it.....John(UK)....fergusontractors@hotmail.com |
| John(UK)
11-18-2012 08:33:06
79.76.250.65
| Check the oil level in the transmission, the dipstick is on the right side round cover below the seat on the side. If there is no dipstick then remove the bottom bolt in the round cover and see if any oil runs out, allow any to run until it stops. If it needs any oil adding to it, fill it at the side of the gear change levers with 10W/30 Multi-grade oil. Check that the Draft Control Lever(the square one) is right at the top of the Quadrant otherwise there won't be any oil pressure, place both levers at the top and then you should have pressure so just operate the spool Valves to operate the implement. The oil should be circulating until you operate the lever on the spool valve. The 3 point being stuck at the top has no bearing on the problem and it will be just lack of use. When you say there is no PTO running, are you sure that you have the PTO Lever lifted to "Engine PTO" not "Ground PTO" but the Pump should be running no matter where the PTO Lever is, unlike the earlier tractors. The PTO drives off the Back of the Pump. If the tractor drives in forward and reverse you should be getting power to the Pump to drive the PTO. If you need the correct info on operating the hydraulics then email me direct at the address below and I will send it....John(UK)....fegusontractorshotmail.com |
| John(UK)
11-18-2012 08:34:13
79.76.250.65
Re: MF 35 hydraulic/pto in reply to John(UK), 11-18-2012 08:33:06
| The email address should have read....fergusontractors@hotmail.com..........John(UK) |
| Jerry/MT
11-18-2012 07:47:16
206.183.116.145
| Is there a selector valve underneath the seat? If so, they normally port pressure from the pump to either a contol valve or to the hitch system. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
