| Harry Ferguson Tractors Discussion Forum |
Topic: Re: Choke linkage
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| John(UK)
11-17-2012 05:07:11
79.76.252.141
They dismantle the Carb and then re-assemble it incorrectly or just forget how it goes and then they cut it off when all it needs at the most is some adjustment, but if they just take the Carb apart they will not disturb the link so there is no need to do anything except to rebuild it correctly, if you get it wrong you simply remove the top again and turn the tube for the link over. Same with the spring on the outside of the choke spindle. Really they just don't know what it is for....John(UK) |
| Dukir
11-18-2012 16:18:08
184.35.92.133
Re: Choke linkage in reply to John(UK), 11-17-2012 05:07:11
| What IS the link for? My TO30 has none. Have had it 30+ years and never removed the carb. Starts fine cold, the 6 volts is a little weak when hot but it gets it started. |
| John(UK)
11-19-2012 05:28:23
79.76.255.179
Re: Choke linkage in reply to Dukir, 11-18-2012 16:18:08
| It is a different Carburettor on a TO tractor and so it does not have that link. The idea of the link is that it speeds up the engine when it is running on choke so that it won't stall and flood. Regarding the Starting, just make sure that the starter leads are heavy enough (gage 0) and that the ground lead is attached to a bolt close to the starter instead of the back of the Dash panel as that will be partly insulated by rust now. All other connection should be clean and bright and tight. Make sure that the Brushes in the starter are not sticking or worn and flashing and that the commutator that the brushes bear down on is not dirty or burnt...John(UK)...fergusontractors@hotmail.com |
| Dukir
11-19-2012 17:38:04
184.35.92.133
Re: Choke linkage in reply to John(UK), 11-19-2012 05:28:23
| Thanks John(UK), I'll be re-routing the ground lead as it IS attached to the dash. Makes sense to run it through fewer contact surfaces. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
