TractorLinks.com
Show Parts for Model:
Re: No oil pressure
Gene in La.
11-15-2012 19:26:17
Radiator I mean the inside, the out side I keep real clean. Oil is ok, 10w30, could use a change but ok. Noise no unusual. When I took pump apart and removed a spring by removeing a carter pin; it effected nouthing???
Jerry/MT
11-17-2012 17:43:33
 Re: No oil pressure in reply to Gene in La., 11-15-2012 19:26:17
Was there a piston at the top of the spring in the releif valve? Was the spring the correct one? It can be shimmed to providea higher relief pressure.When you say "it affected nothig" what do you mean?
John(UK)
11-16-2012 07:37:19
Then it looks like either the pump is worn or the bearings on the crank....but check the pump for wear...John(UK)...fergusontractors@hotmail.com
