Standard Engine Rocker Bushings TEA20
Hello has anybody found rocker bushings available for the standard 85mm engine, you need 16 half bushings to do the whole job, ferguson part nomber 825 108 M1, I havent seen them available anywhere but somebody may know thank you
non of the usual suppliers have them, but I have just emailed a contact I have at MF/AGCO to see if they are available anywhere and I will also contact another supplier that often has odd parts. You could try the Triumph sports car club in Australia to see if they know as the engine is very similar and the valve gear will be the same on one or more of their engines.I will let you know when I get a reply from MF...John(UK)[email protected]
Matt, Sorry about the delay in getting an answer for you about the Valve Rockers etc. Massey-Ferguson have no stock at all now, they have checked worldwide.
At the present time there are none available from the usual suppliers, I know it wont help you right now but I have contacted both Sparex and Agriline to see if they have any stock or if they plan to produce them, they have both said that they will look into the possibility. I know that doesn't help you immediately, but maybe it will in the future...John(UK)[email protected]
Matt. If you have the dimensions have you tried one of the engine overhaul shops? They seem to find all these odd parts when needed.
I have a local machine shop here in Roma (Qld) that may be able to make them for you at reasonable price.
Bob in Oz
