TractorLinks.com
Show Parts for Model:
Re: Blocked cracked by starter, any way to fix?
ruger1
11-12-2012 08:54:29
Both starters have 9 teeth on the gear. The new starter does not have anything stamped on the body. I checked the flywheel teeth more closely. There was an area on the flywheel where there was significantly more wear on a few teeth. A few inches away from that areathere was a tooth that was broken in half. I will measure the starter diameter later on.
In regards to the fix, i understand what you are saying in regards to the bridge. After closer inspection there is a hairline crack above the the upper hole also. What if i hade a plate made up the fit into the cutout area where the starter mounts?. This plate would have the starter hole and mounting bolts cutout but would also have the two bolts in that area that are used to bolt the block and tranny together also cutout. That way these two aditional bolts would help support the entire area. The only issue would be the plate thickness would affect how far the starter goes into the block. Would this be possible with a thin enough plate?
