TractorLinks.com
Show Parts for Model:
Re: Blocked cracked by starter, any way to fix?
John(UK)
11-12-2012 07:05:18
If you have fitted a new or different starter, this could be the problem. On the original starter there was a lip all the way around the face where it sits in the hole for the starter in the block. If this lip is wrong dimensions, it would cause your problem, compare it with the original starter.
With the starter not mounting correctly, it will not mate up with the block properly and will be mounted at an angle instead of square-on to the Block. The lip was to provide support for the starter and take the load off the bolts.It would also be the cause of damage to the teeth on the Ring Gear...John(UK)....fergusontractors@hotmail.com
