Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Blocked cracked by starter, any way to fix?
Bruce(OR)
11-12-2012 06:29:03
In my ignorance, I would tend to suspect you need to remove the engine to inspect clearances. Especially when mounting the starter. What is the clearance between the starter drive and the flywhhel when engaged? Then I might be sorely tempted to mount studs to hold the starter in place. As this is also a cast iron block you might need to find an oven and a welder who knows what they ae doing. The fun part is not the heating of the block to weld it properly, the cooling is what is more critical. Now if not possible to get this done for under $250, the $500 block below becomes a good deal. But you still get to mount your starter and check clearances. Unless you like repeat performances. . .
