Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Adding remote hydraulics to TO-35
Inno
11-01-2012 19:55:46
Boss Hog said: (quoted from post at 17:47:06 11/01/12) My Dad has one like that on his MF 65. As you guessed, you can not use the 3 point and the hydraulics at the same time.
The hydraulic pump on his tractor (and yours) does not have a lot of volume, so anything you do with cylinders will be slow.
Thanks. I have no need of anything fast, just as long as I can adjust the angle of my back blade and top link without having to get off the tractor. Once the adjustment is made I can go back to using the 3pt. More for convenience than anything else as I'm aware that there isn't a lot of volume from the internal pump.
Tony, I was pretty sure that's what everyone was talking about. I'd like to see one all plumbed up if someone has a picture.
My needs or expectations are for one, maybe two double acting valves to be used for making adjustments to implements, slow is fine. Then once the adjustments are made, go back to using the 3pt. One or the other is fine..........don't have enough hands for anything else! :)
This post was edited by Inno at 20:01:22 11/01/12.
Copyright © 1997-2015 Yesterday's Tractor Co.
