Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Adding remote hydraulics to TO-35
[Show Entire Topic]  [Return to Forum]
John(UK)
11-01-2012 07:11:14
79.76.255.34
Feed your new valve from one of the plugs with the hexagon hole on the side of the Top Cover. Pipe up you selector valve as you want it. and lift the Draft Lever to the top of the quadrant. You now need to move your selector valve to operate the implement that you are controlling and it should work if you have it piped correctly. To operate the 3 point, lift whatever remote implement or Hydraulic cylinder you are using and move the selector valve so that it will lock this in the raised position, now just lower the Draft Control and operate it as normal.Then implement or ram will stay up as long as the valve and pipework has no leaks.No need to disconnect anything. The return from the selector valve attach es to the Top Cover on the Left side just forward of the Cross-shaft, do not return any oil through the filler plug alongside the Gear Levers. I am assuming that the cylinders you intend to use are double acting, if they are single acting the pipework is slightly different but more or less the same.To change from the implement to the 3 point, all you do is move the selector valve and the use the Tractor controls as normal. If you need more info and tell me exactly what you are using single or double acting rams I will send you a diagram that shows how to connect everything.There are quite a few ways to do this some more complex than others, you can use the tractor controls instead of a Valve assy, just use a selector valve to divert the oil...John(UK)....fergusontractors@hotmail.com
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
