Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: To30 Lift will raise but will not lower
Jerry/MT
10-31-2012 18:35:00
The control valve is most likely stuck. With the engine off, pull the RH side plate and look for the "H" shaped control fork hanging down. Reach down and make sure the "T" shaped control valve lever is in the "H" shaped control fork sockets. Pull back on the control valve and the lift should drop. There is most likely a lot of crud in fluid and it"s probably milky colored from water. If so, you need to replace it and it would be a good idea to clean the sumps since the tractor has sat outside for so. Jeff(OH) has a cleaning method and it"s in the archives
Jason S.
11-01-2012 08:42:35
 Re: To30 Lift will raise but will not lower in reply to Jerry/MT, 10-31-2012 18:35:00
My TO20 would do the same thing...I ended up replacing the control valve. Where it had sit for a long time before I got it...water in the hydraulic oil had kind of pitted the control valve. Even though it was just a few spots...it would stick. I replaced it and readjusted everything and it has been fine ever since.
Copyright © 1997-2015 Yesterday's Tractor Co.
