TractorLinks.com
Show Parts for Model:
Re: To30 another 12 volt conversion thread.
John(UK)
10-31-2012 04:54:30
Get a proper tractor battery, they are more expensive but they last longer and the vibration will cause a standard battery to break up inside. You can use the 6 volt coil if you wish but a new 12 volt coil is better. You can use the original 6 volt Starter just make sure that the Engine starts easily or you could burn it out if you need to keep turning the engine to get it to start, so the Points and the Carb need to be set correctly. The pulley on the Alternator needs to be smaller than the one that was on the Generator so it turns faster, if you don't use a larger pulley it won't start charging unless you "blip" the throttle each time you start. either 1 or 2 wire is OK, possibly 2 wire is better. The belt MAY be OK it just depends if the one you have is the right size now. The belt should be running level with the top of the pulleys, not part way down the Vee or it will be driving on the bottom of the belt rather than the sides. An Alternator takes more driving than a Generator so the belt needs to be right first time. If you want the information about timing the ignition and setting the Carb. OR anything else, just email me at the address below and I will send it...John(UK)..fergusontractors@hotmail.com
