TractorLinks.com
Show Parts for Model:
Re: electronic ignition
JMOR
10-29-2012 11:43:59
Quoting Removed, click Modern View to seeWell, Al, since EI is such a lightening rod, you shouldn't have mentioned it as so many responses have nothing to do with helping you with your problem. I say, forget that you have EI, as if it is firing 3 cylinders alright, it is also producing the same output for the 4th cylinder........so, the problem is between the coil output & the plug or the plug itself, or you have mis-diagnosed the problem & it isn't ignition. I would do a compression test if I were working on it. Yes, I read what you said about the timing light.
Al Clark
10-29-2012 12:14:31
 Re: electronic ignition in reply to JMOR, 10-29-2012 11:43:59
JMOR, See below, my distributor contacts are chewed up,expecially #4. The distributor shaft has excessive play. The #4 cylinder fires erratically. I think the distributor is the problem.
