TractorLinks.com
Show Parts for Model:
Re: Same TE 20 New Problem
Jerry/MT
10-28-2012 12:40:40
What"s plugging the head? Is it lime deposits? If so, I wonder if taking it to a machine shop and having it hot tanked will clean it up? Are you sure it"s just the head?
DON TX
10-28-2012 13:09:37
 Re: Same TE 20 New Problem in reply to Jerry/MT, 10-28-2012 12:40:40
I assume it's rust. Could be anything. The system has been closed so don't suspect mice or other critters. When I drained it to remove the radiator the water was very rusty. With the w/p removed the block drains thru the opening created and the block drain works. As I said, I'm trying to do this w/o removing the head. I don't want to get into the valve train. It'll have to be removed to tank it. Don't want to open a can of worms unless it's necessary.
DON TX
Jason S.
10-29-2012 06:11:20
 Re: Same TE 20 New Problem in reply to DON TX, 10-28-2012 13:09:37
Have you tried blowing air thru the passages? I know it will make a mess and blow water and rust all over you but it doesnt sound like you have too many options left besides removing the head.
Jerry/MT
10-28-2012 19:25:46
You may not have a choice if it"s that blocked up. There"s not a lot of skinny passages in the head that I recall so I can"t imagine it"s just rust. Maybe someone put muddy water in there in an emergency.
I"d try a good radiator flush(Prestone Flush?). Any way you can hook a hose fitting to the block drain and back flush it?
