TractorLinks.com
Show Parts for Model:
Re: Same TE 20 New Problem
DON TX
10-28-2012 10:45:06
Reread my 1st post. I removed the tstat to find no circulation. The head is plugged. I have the goose neck removed and filled the head. The liquid is sitting to the rim of the head. It does not flow down to the water pump. Is there anything I can use to clean the head without removing it?
DON TX
Jerry/MT
10-28-2012 12:40:40
 Re: Same TE 20 New Problem in reply to DON TX, 10-28-2012 10:45:06
What"s plugging the head? Is it lime deposits? If so, I wonder if taking it to a machine shop and having it hot tanked will clean it up? Are you sure it"s just the head?
DON TX
10-28-2012 13:09:37
 Re: Same TE 20 New Problem in reply to Jerry/MT, 10-28-2012 12:40:40
I assume it's rust. Could be anything. The system has been closed so don't suspect mice or other critters. When I drained it to remove the radiator the water was very rusty. With the w/p removed the block drains thru the opening created and the block drain works. As I said, I'm trying to do this w/o removing the head. I don't want to get into the valve train. It'll have to be removed to tank it. Don't want to open a can of worms unless it's necessary.
DON TX
Jason S.
10-29-2012 06:11:20
 Re: Same TE 20 New Problem in reply to DON TX, 10-28-2012 13:09:37
Have you tried blowing air thru the passages? I know it will make a mess and blow water and rust all over you but it doesnt sound like you have too many options left besides removing the head.
Jerry/MT
10-28-2012 19:25:46
You may not have a choice if it"s that blocked up. There"s not a lot of skinny passages in the head that I recall so I can"t imagine it"s just rust. Maybe someone put muddy water in there in an emergency.
I"d try a good radiator flush(Prestone Flush?). Any way you can hook a hose fitting to the block drain and back flush it?
