My TE20 with Z120 in fact has flywheel timing marks. Is that factory or did a PO put a flywheel from a TO20 on it at sometime in the past????
If all TE20's in fact have the flywheel timing marks then how many teeth are on the flywheel starter ring gear??? Knowing the numbner of teeth will allow any owner to remark flywheel to allow timing lite at the lower sheet metal bellhousing cover.
Yes, yes i know the SM defines a procedure to remark the crank pulley at the front for better access. But i don;t like it.
