TractorLinks.com
Show Parts for Model:
Re: Same TE 20 New Problem
John(UK)
10-24-2012 07:34:51
Check compression on all cylinders by turning he Engine with a starting handle if you don't have a pressure gauge, you may find two compressions down and in that case suspect a Head Gasket initially, until you have had a look at it. also are you sure that the Plugs leads are on the right plugs, they can run after a fashion wrongly wired. From how you describe the water level rising and falling I would suspect a pressure leak, either the Head Gasket or the Head itself. It could of course be a Sleeve gasket that has compressed and it would look like it was a Head gasket leaking, but you would need to check the sleeve "stand-out" from the Block Face for that...John(UK)...fergusontractors@hotmail.com
