TractorLinks.com
Show Parts for Model:
Re: to35,z134 overhaul update
Ed H.-OH
10-21-2012 15:34:41
Duner,Hello, Thanks for the information. Mine is not cracked, but if it was I would attempt the bolt thing for sure as the block is junk anyway. I'm sure if the crack is pulled shut and supported it could be sealed up and save the block.The one's i seen looks like they drilled midway between the top and bottom web to support both. If the botom web is only cracked it looks to me that you could go strait through the block with a rod just below the crack and avoid drilling the stud bosses. the rod would just clear going over the cam and out through the block behind the starter. The block is tapered there on carb side,so you would have to make a tapered washer to conform. I hope i don't have to go there as the overhaul is enough for me, I'm interested in it as it would be nice to help people with this problem.-ed
