| Harry Ferguson Tractors Discussion Forum |
Topic: to35,z134 overhaul update
[Return to Forum]
| Author |
[Modern View]
| Ed H.-OH
10-20-2012 15:08:31
72.23.247.131
     Guys Hello, Me and my son pulled the engine the rest of the way down, I"m pleased to say there are no signs of cracks in the webbing.Everything is in remarkably good shape for a 57 yr. old engine. I bought $780.00 worth of parts today, Including head kit with new valves and guides,springs, oil pump kit,liners and pistons,all new bearings . The liner that leaked was rotting around the packing(see pic). Now it"s just a matter of cleaning it up and reassembly.OLD HARRY"S GOING TO ROAR AGAIN LOL -CHEERS -ED |
| PackardV8
10-22-2012 18:53:45
205.188.116.142
Re: to35,z134 overhaul update in reply to Ed H.-OH, 10-20-2012 15:08:31
| DUner. Thanks for the Smokestak.com link. Very helpful. I mite have to do the threaded rod trick after all. The SmokeStak article answers alot of questions. -PV8 |
| Ed H.-OH
10-23-2012 13:58:13
72.23.247.131
Re: to35,z134 overhaul update in reply to PackardV8, 10-22-2012 18:53:45
| PV8, Hi!, The push rod cavity is open full legnth of the block , the only exception is the lifter mount blocks forged between the 2 walls. ed |
| Duner Wi
10-22-2012 18:58:33
216.226.80.242
| I thought you might find it interesting. Hope I never have to try it. |
| PackardV8
10-21-2012 06:38:40
64.12.116.19
| Since the cylinder liner is corroded then is the corresponding area of the block as equally corroded????? If so then that mite create a sealing problem. |
| Ed H.-OH
10-21-2012 08:43:09
72.23.247.131
Re: to35,z134 overhaul update in reply to PackardV8, 10-21-2012 06:38:40
| Packard Hi!, The block bore is fine, just eat the liner, As for the bolts through the block, I have never seen the inside of one that has been done so like you I can only guess how they did it. The bolts only show on the oil fill side as i recall. They must drill through the stud bosses and tap the hole in the one near the cam. Someone in my area is doing it as i've seen a coupple of them. I wish i could be more help-ed |
| Duner Wi
10-21-2012 13:41:28
216.226.80.242
Re: to35,z134 overhaul update in reply to Ed H.-OH, 10-21-2012 08:43:09
| Pretty sure I have seen pictures on this site of bolted blocks but I can't find them now. I did find this. smokstak.com/forum/showthread.php?t=63589 |
| Ed H.-OH
10-21-2012 15:34:41
72.23.247.131
Re: to35,z134 overhaul update in reply to Duner Wi, 10-21-2012 13:41:28
| Duner,Hello, Thanks for the information. Mine is not cracked, but if it was I would attempt the bolt thing for sure as the block is junk anyway. I'm sure if the crack is pulled shut and supported it could be sealed up and save the block.The one's i seen looks like they drilled midway between the top and bottom web to support both. If the botom web is only cracked it looks to me that you could go strait through the block with a rod just below the crack and avoid drilling the stud bosses. the rod would just clear going over the cam and out through the block behind the starter. The block is tapered there on carb side,so you would have to make a tapered washer to conform. I hope i don't have to go there as the overhaul is enough for me, I'm interested in it as it would be nice to help people with this problem.-ed |
| PackardV8
10-20-2012 18:27:15
64.12.116.137
| Here is a pic of my TE20 Z120 cylinder web from the UNDER side. Between #3 and #4. |
| Jerry/MT
10-20-2012 18:08:37
206.183.116.145
| The webs between the cylinders seem thicker (~2X) than they are on the Z120 and Z129 blocks. Good luck on the overhaul and let us know how it goes. |
| Ed H.-OH
10-21-2012 08:13:28
72.23.247.131
Re: to35,z134 overhaul update in reply to Jerry/MT, 10-20-2012 18:08:37
| Jerry, Hello, How are things out in the big empty,I have never seen the z120-29 but i have heard other people say the same thing, so i beleave you are correct. I cannot tell you how pleased i am That it going to go back together ok, as i like that old tractor. -ed |
| Jerry/MT
10-21-2012 21:12:17
206.183.116.145
Re: to35,z134 overhaul update in reply to Ed H.-OH, 10-21-2012 08:13:28
| Pretty dry over here! Need some rain. I"ve had to start feeding the pairs and we"ll be preg checking the cows and weaning the calves this weeekend. It"ll be noisey for few days. |
| PackardV8
10-20-2012 18:04:37
64.12.116.199
| Hmmmmmmmm. On second thot, after viewing the pics with a bit more study it appears that the cyl head stud bosses extend all of the way thru the height of the block. Therefore attempting to drill block Xversely for a long pinch bolt may be impossible or very poor idea. |
| PackardV8
10-20-2012 17:58:56
64.12.116.137
| Ed. Many thanks for posting the pics. That is the first time i've ever seen inside of a Ferguson block ( with head removed) despite the fact i have a factory service manual,parts cataloug as well as owners manual and an IT service manual.
WHile u have it apart. Cheque the valve push rod chamber in the block. Does the chamber run full length of the block or is it 4 seperate chambers, one chamber for each cylinders 2wo push rods.
The reason i ask is that if at some future date cracks should occur at the lower cylinder webs (apparently many such reports) then knowing how to drill the block to install a threaded rod transversly thru the block is important. Mite want to mark the block externaly for future hole drilling reference should it become necessary.
This post was edited by PackardV8 at 18:22:35 10/20/12. |
| miner09
10-20-2012 15:25:47
75.222.71.243
| When you put headbolts back in block put Permatex on threads so they will not leak.This is a problem they have. |
| Ed H.-OH
10-20-2012 15:28:16
72.23.247.131
Re: to35,z134 overhaul update in reply to miner09, 10-20-2012 15:25:47
| Miner, Thanks for the heads up, Will do-ed |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
