Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Filter spring size?
2tractors
10-17-2012 16:31:00
Been a while since I've been in a 20 but do remember posting the order once in the archives, I had to cut somre rungs off an old bed spring until it held the "basket" flush against the oil pan. Make sure the pipe has the center hole clear. Install the spring and basket then the felt washer then tie it with wire so it doesn't fall down then install the pan, reach inside remove wire and install filter then the round cover with gasket
DON TX
10-17-2012 20:14:05
 Re: Filter spring size? in reply to 2tractors, 10-17-2012 16:31:00
Ok, you just informed me there is something else missing. The "basket". Great. What do I do about that. Chances of finding a used one won't be very likely since it sounds like they damage easily. Looked in YT, Stieners and no new part available. I wonder how important it is if you change oil on a timely basis you won't have to worry about gobs or junk building up enuff to bother the filter. I'll have to think about this.
DON TX
2tractors
10-18-2012 05:08:38
 Re: Filter spring size? in reply to DON TX, 10-17-2012 20:14:05
The basket is something similar in shape as the "pan" and is a screen mesh like a colander or strainer.I don't think its all that necessary.I've never found a big glob stuck between the screen.
2tractors
10-17-2012 16:39:09
After looking in the archives there is also a "pan" so its spring,pan,basket,washer filter.
Copyright © 1997-2015 Yesterday's Tractor Co.
