Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 80-140
[Return to Forum]
miner09
10-15-2012 17:11:17
75.255.193.92
Is 80-140 gear oil to heavy for F40. I can't find 90 wt in a 5 gal. can. I can get it in qts.($5)Everyone has the 80-140.($55 for 5 gal) Only for show and will not be running it in cold weather. Will power lift work OK with heavy oil.
[Reply]   [No Email]
maxwell99
10-16-2012 11:58:37
208.92.104.67
 Re: 80-140 in reply to miner09, 10-15-2012 17:11:17
i buy my 90 weight gl-1 fergy trans/lift oil at napa.
best price i have found and they sell it by the gals.
right stuff for your brass or bronze bearings in your trans,
remember: it the bearings in the trans that need the right oil!!!!!!!!!!!!!
what good is a tractor with a good lift system if the bearings in the trans are out?
[Reply]  [No Email]
samn40
10-16-2012 15:09:44
217.43.214.254
 Re: 80-140 in reply to maxwell99, 10-16-2012 11:58:37
Maxwell, if 15W30 is good enough for tractors over here it will do in America,plus you have the benefit of instant hydraulics in winter. Bearings and bushings are not a problem in the 35/40/65 etc, maybe in the TE and TO range there was an issue. Micky, a couple of drums of 15W30 will sort out your hydraulics and a couple of engine oil changes also.....
Sam
[Reply]  [No Email]
Tony in Mass.
10-16-2012 06:50:46
76.127.225.182
This goes back to the threads a few months ago about what to pour in there- the 90 'mineral' is more like an engine #30, which I suppose is why 15w-40 is now acceptable to put in, but the 80-140 you mention... is the old fashioned standard transmission/ differencial oil... small bottles had the cone shaped cover do get into the diff plugholes, it's more of a syrup than an oil, nope. I wouldn't put that in there nope.
After dealing with the sheared bolts in the diesel and looking at the welding job someone did on the TO35 cover..... nope.
Go buy a pail of - OK 2 pails- of 15w40, you will have 2 gallons left for an engine oil change, and atleast nothing will break due to wrong fluids.
[Reply]  [No Email]
Jeff-oh
10-16-2012 05:29:06
69.174.58.116
NAPA has the 90 wt. GL-1 oil. PN 65-205 (5gal. bucket) 65-201 one gal. jug.
They may have to get it in from the wearhouse.
[Reply]  [No Email]
Jeff-oh
10-16-2012 05:33:19
69.174.58.116
 Re: 80-140 in reply to Jeff-oh, 10-16-2012 05:29:06
Just re-checked the PN's are still correct.
[Reply]  [No Email]
John(UK)
10-16-2012 02:09:44
79.76.252.230
That oil you mention is far too heavy, while you could use it in the transmission, it is the hydraulics that you have to consider, it is far too heavy and would cause the control Valve to stick and could also cause too much pressure to be developed and that could cause parts to crack due to the pressure. The oil that you should use now all year round and it is OK in hot or cold climates is Multi-grade 10W/30, this will remain fluid down to -25 and it is a good oil to use for the transmission because of how it is blended, it has anti-wear properties which is a big help on these hydraulics. Change the oil every 12 months and only when it is hot, leave it draining over-night and then refill 2 gallons at a time leaving some time before you add the next lot or the level could rise too high in the transmission and run through into the Clutch Housing. It doesn't matter that you are not using it in a cold climate, this oil is good for any use. A thinner oil is always better than a thick gooey one for hydraulics and it will spray around the inside which will help to prevent rust and condensation when it is standing long periods.DON'T use diesel or Kerosene to wash out the interior of the transmission as you can't drain it all out due to the shape of the floor of the housings, just drain it when hot..John(UK)....fergusontractors@hotmail.com
[Reply]  [No Email]
samn40
10-15-2012 19:10:52
217.43.214.254
Use 15W30 or 40 engine oil for best preformance all year round! All the many, many Massey Fergusons on our side of the big pond run on nothing else and they all live to tell the tale!. 90 weight or any other oil has never been specified here in my time working with these transmissions/Tractors.
Sam
[Reply]  [No Email]
d beatty
10-15-2012 19:02:43
24.12.128.253
You can get 80-90 at almost any auto supply and Tractor Supply. The price runs about the same as 80-140.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
