My TO20 has been leaking at the axles and i have no brakes so I figure I'd put some sure seals in it and fix the brakes. I tear it down and find brand new brake shoes on it, although oil soaked. Pull the axles and find sure seals already on it. I pop them out and find it has new bearings but the bearings were never packed with grease.... And the shims were covered in red silicone and there was no gaskets on either side of the brake backing plate. So...I'm off to get some gaskets at the dealer...I think the bearings are ok because there was enough oil pouring thru there to keep them lubed but I have to pack them and then check the end play once i get it back together.Anybody else ever run into a mess like this that someone has done?
