TractorLinks.com
Show Parts for Model:
Re: To35 z134 Liner packing leak
PackardV8
10-14-2012 08:35:59
Thanks for the slick trick tip on the hardened threaded rod. I mite try that instead of the marine grade epoxy i was getting ready to use in about an hour from now. When the threaded rod is used is there anything else that needs to be done other than the obvious sealer on the nuts at the outside of the block???
Ed H.-OH
10-14-2012 09:04:37
 Re: To35 z134 Liner packing leak in reply to PackardV8, 10-14-2012 08:35:59
Packard, Hi!, I don't know if it's workable on the to20 engine , I,ve never been close to one. But i have seen at least 3, z134's with 2 bolts through the block holding the webbing together. The last one i seen was a mf 135 and it looked like it had been done years before, The guy clamed it runs great, he didn't even know the block had been repaired.I don't know this for a fact' but i've been told the web between 1-2 has an oil passage through it on the z134. when cracked will leak oil pressure into the radiator. Thanks for the come back-ed
