TractorLinks.com
Show Parts for Model:
Re: Removing oil pan TE 20
mwferg
10-13-2012 09:27:58
Two things with te20. First, check the pan where the filter removal housing contacts the pan. over time and use, the pan gets distorted there, and the housing gasket won"t seal. I"ve had to use a wood block from the inside of the pan to drive the pan surface back out and flat. also, if you are using gasket silicone, make sure that you put it far enough toward the outside of thesurface at the rear of the engine. the block has a narrow surface there so that a socket can be used to torque the rear main.
