Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Removing oil pan TE 20
[Return to Forum]
DON TX
10-10-2012 14:39:27
76.196.6.124
In order to remove the oil pan, do I need to take the long rods on each side of the engine off ?
DON TX
[Reply]   [No Email]
mwferg
10-13-2012 09:27:58
71.209.107.112
 Re: Removing oil pan TE 20 in reply to DON TX, 10-10-2012 14:39:27
Two things with te20. First, check the pan where the filter removal housing contacts the pan. over time and use, the pan gets distorted there, and the housing gasket won"t seal. I"ve had to use a wood block from the inside of the pan to drive the pan surface back out and flat. also, if you are using gasket silicone, make sure that you put it far enough toward the outside of thesurface at the rear of the engine. the block has a narrow surface there so that a socket can be used to torque the rear main.
[Reply]  [No Email]
John(UK)
10-11-2012 06:33:47
79.76.241.105
It is easier with both rods removed...John(UK)...fergusontractors@hotmail.com
[Reply]  [No Email]
PackardV8
10-11-2012 05:02:41
64.12.116.19
Should u try to remove pan by removing only one strut rod then remove the right side. I'm trying to recall here. In my case the oil filter cannister INSIDE the oil pan was removed previously and the oil float kind of gerry rigged someway. SO if yours still has filter cannister then it mite be impossible to remove oil pan by only removing one strut rod.
I have a To-20 and a recent TE20. I am NOT impressed with the TE at all.
Heed my warning from above about that Al trans housing. Do not over
torque the bolts when reinstalling the strut rods.
Also cheque the front pivot bracket that bolts to the engine. Mine has a 1" x 1" square cut from it up near the rite side mounting bolts. TO20 does not. My pivot bracketr is cracked at the square cut out. I belive the square cut out is factory but i'm not sure.
Quite frankly, the TE 20 i have (not rusty at all and appears to have ben well maintaned) has a lot of very poor eng'ring that varies from my TO-20.
The AL transmission housing is probably the most brainless idea i've ever seen in my 40 years of wrenching on junk.
[Reply]  [No Email]
PackardV8
10-10-2012 19:51:08
205.188.116.19
Recently removed pan from my TE-20 by removing only one of the rods. Can't remeber if it was left or rite. HOWever, the last time i did it i removed BOTH rods. REmoving only one rod makes it much more difficult. Not worth it, just remove both of them.
When installing the rods be very careful not to overtorque bolts in trans. Trans is Aluminium and they strip very ez.
[Reply]  [No Email]
DON TX
10-10-2012 20:48:58
76.196.6.124
 Re: Removing oil pan TE 20 in reply to PackardV8, 10-10-2012 19:51:08
I figured so. Was hoping for a magic procedure. They look like a challenge with the rust and paint. Heat and PB Blaster on order. Thanks
DON TX
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
