Ferguson 35
2004 Dmax
New User
Hello i am new to massey feguson and wondering if the front end from a massey 20 will fit in a massey 35? thank you.
The complete axle will fit as long as the fulcrum pin will go through the bush. Check the engine cradle as I am not familiar with the front mounts of the z120 and z134 engines. The axle beam on TE20s is lighter than the Fe35 axle, and it is probably that way on your side of the Pond, but it does still fit.
Sam
The axle carrier should fit if it is the same engine. The axle is heavier so it may not fit the old carrier. The Pivot Pin may be longer and heavieer on the 20..John(UK)
