Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Tractor stalling
[Return to Forum]
wforpm
10-09-2012 09:16:22
71.184.118.31
OK , having a strange thing going on. TO-30 when first starting , starts right up with choke lever all the way out. Will run at half choke for a couple of minutes. Then if you set to no choke it will stutter and cough , until it gets hot. Once its hot , 15-20 minutes , then It runs fine. After taking it out of the garage and moving around , if it is on a bumpy surface or using the loader, it runs realy rough , stuttering and coughing like its got COPD ! Then is will stall.Just like some one turned the key off. If you try to restar it it just cranks over. After it sits for a couple of minutes it will start back up. and seems fine. Any ideas?
Thanks.
[Reply]   [No Email]
rusty nut
10-14-2012 17:28:37
67.240.59.220
 Re: Tractor stalling in reply to wforpm, 10-09-2012 09:16:22
let me know what you find out,my to30 does the same thing,i put new fuel line and fuel filter also put a fuel shutoff at the carb(takes place of the elbow screen,I think for some reason it isn't constantly getting fuel,with mine I'm thinking the screen in the gas tank that is attached to the sediment bowl sometimes gets plugged.good luck.
[Reply]  [No Email]
Inno
10-10-2012 07:12:13
206.172.0.204
Even new coils can be defective, if you have another one to stick on and try it, it would be a quick way to rule it out.
[Reply]  [No Email]
wforpm
10-10-2012 06:15:42
71.184.118.31
Has a new coil , just replaced it last month. 12 volt. I'll check the linkage settings and start there.
Thanks , will keep all posted.
Bob
[Reply]  [No Email]
Inno
10-10-2012 04:45:02
65.95.123.154
Could also be a bad coil, getting hot and giving weak spark.
[Reply]  [No Email]
Bruce(OR)
10-09-2012 21:17:17
97.115.27.135
Bump and die. . .
Bad switch?
Got spark when cranking hot?
Or just intermittant???
[Reply]  [No Email]
Inno
10-09-2012 17:04:03
65.95.123.154
 Re: Tractor stalling in reply to Jerry/MT, 10-09-2012 09:16:22
The throttle should have much more range than that. Could be a governor issue. When it's sitting there idling and you crack the throttle and bring it up to high speed, does it go smoothly or does it sputter? Is the choke staying open when operating, sometimes when I'm using the backhoe on my 202 the choke will come on causing it to not run right and if I don't get to it quick enough it will flood (needs a new spring).
[Reply]  [No Email]
wforpm
10-09-2012 16:06:28
66.30.168.126
OK , checked the screen @ carb., nothing , checked the fuel line to carb. removed the line and opened the gas tank shut off , gas flows like river. Have been opening the fuel screw ( large one ) on the carb. 1/8 at a time. Nothing better. This is a new carb. When she's sitting it runs very good, female LOL , she acts different than when out working, could it be the float ? Did not check or set when put it on. ALSO , throttle only moves about 1 to 1-1/2 inchs from idle to full throttle. Not 65 deg. like the manual.
Stumped ?
[Reply]  [No Email]
mwferg
10-09-2012 13:42:24
71.209.107.112
If you don"t already know, there is a screen filter in the brass elbow that feeds fuel to the carb. This is often overlooked. My te20 did the same thing several years ago, and that was the problem. Take the elbow off of the carb and blow out the screen that comes out with the elbow.
[Reply]  [No Email]
2tractors
10-09-2012 10:47:56
207.144.5.133
One of the many fuel screens is parcially clogged, maybe inside the tank or carb or the fuel bowl, most times when you have to pull choke to make it run your not getting the gas to carb.
[Reply]  [No Email]
David G
10-09-2012 10:10:47
204.29.138.33
I would take the drain out of the carb and see if junk runs out, also open up the power circuit about 1/2 turn.
[Reply]  [No Email]
John(UK)
10-09-2012 11:50:29
79.76.253.208
 Re: Tractor stalling in reply to David G, 10-09-2012 10:10:47
Opening the main jet 1/2 turn is far too much at any time, do it 1/8 turn at a time..John(UK)
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
