Dan S (NY)
The main shift lever on my MF35 diesel can rotate the entire ball cup back and forth, which makes it very tricky to shift. Where these just pressed into the steering box/trans cover housing? I need to secure this in place somehow. Was thinking maybe JB weld might hold it enough?
Also, the high/low shifter was binding and I found out why. The cup on on the hi/low stick was pushed down some which caused the stick to bottom out in the shift rail socket. Hopefully it will press back in.
Dan
Dan
