TractorLinks.com
Show Parts for Model:
Re: TE 20 Rear Axle Question
PackardV8
10-07-2012 08:23:29
NOTE!!! When adjusting end play for LEFT shaft be sure that the RITE shaft is pushed IN and remains pushed in all of the way. Do the same for the Rite side adjustment. Make sure left shaft is pushed in all of the way.
ALSO, if u find that many shims are required on one side and none on the other then it mite be advisable to re-shim in an effort to have (as close as reasonably possible) the same number of shims on each side.
IIRC this covered in the service manual. U should have such a manual. It is important. There are several hidden secrets about the Ferguson that i would have missed had i not had the manual.
This post was edited by PackardV8 at 08:26:31 10/07/12.
PackardV8
10-07-2012 08:41:06
 Re: TE 20 Rear Axle Question in reply to PackardV8, 10-07-2012 08:23:29
IIRC the manual indicates shims (for TO-20) between backing plate and axle. Shims MITE have been installed between hub and backing plate.
I am surprised u did not find any shims at all. If a shop did the press work for u then maybe they did not return shims to u.
