TractorLinks.com
Show Parts for Model:
Re: TE 20 Rear Axle Question
John(UK)
10-07-2012 05:48:33
You have too many shims fitted you need to remove some and test it again. There is a correct procedure for setting this, it is not just a matter of sticking it all back together. If you run with the end-float in the axle, it will, over a period of time knock the Collar off the Axle-shaft and destroy the shaft as well. If you need the correct info on how to set the End- Float, email me direct at the address below, tell me what you are wanting (as I will forget) and then I can send it to you...John(UK)...fergusontractors@hotmail.com
