terry kubiak
MY 48 TE20
6 volt system
So the generator is in , Indicator light goes off at higher idle.
However don't show a significant charge at the battery and if I disconnect a terminal the tractor dies which says no charge.
Has the lucas regulator.
Does this indicate regulator issues.? Will the Delco TO 20 regulator work on this system?
Any wiring changes required or hook it up in the same way.
Thanks again as always.
6 volt system
