Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: generator/ regulator
10-05-2012 08:31:36
It is most likely the Regulator, but you can test the Generator, by removing wiring from Generator, remove Fan Belt.You can buy a Lucas Regulator from this site if needed. Fit a wire between large terminal on Generator to battery, fit a wire between the small terminal on Generator to ground. If the Generator is good it will start to spin like a motor, if it doesn't spin it needs changing. A Delco Regulator will need rewiring ...John(UK)
terry kubiak
10-06-2012 09:58:48
 Re: generator/ regulator in reply to John(UK), 10-05-2012 08:31:36
John if I need to get a Delco regulator what would be required as re wiring ? will be double checking the generator shortly. Keep you posted . thanks again.
10-07-2012 05:42:21
 Re: generator/ regulator in reply to terry kubiak, 10-06-2012 09:58:48
Terry,If you need to do that, then email me direct at the address below I will be able to send the diagram to you..John(UK)
terry kubiak
10-05-2012 14:50:39
Thanks to you both.
Wil give it a try John. Let you know the result.
Also dropped an inquirery as to a new regulator with the parts people.
