| Harry Ferguson Tractors Discussion Forum |
Topic: Re: TO-35 Dual Stage Clutch Adjustment
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| John(UK)
10-01-2012 03:22:13
79.76.250.91
The only adjustments for the Wheel drive Clutch is the Pedal and the Levers on the Clutch assy. You can set the pedal externally, but to set the Levers you need to split the tractor. From how you describe it the Plate is sticking to either the Flywheel or the Clutch and that is why it grinds. But usually when you get that problem there is some judder as you take up the drive. There is also another problem that happens very occasionally and that is the Plate is sticking to either the Flywheel or the Clutch due to a vacuum holding the polished linings to the Clutch. The way to overcome that is to drill all the rivets with a small hole. So check the pedal adjustment which should be 3/8" between the underside of the footrest and the top of the pedal lever, when you press the pedal lightly to remove the free-play. The pedal adjustment should be done when the tractor is warm when everything expands. If that doesn't cure it, then take out the Engine and Check the Clutch for wear and re-set the Levers, check the Plate for wear, how close to the top of the linings are the top of the rivets, is there much wear left in the Plate. If it is sometime since the Clutch had any attention then the Clutch itself can be worn where the Levers pivot and while the pedal is giving you the correct feel, the Clutch is not opening enough. There is very little movement between the 2 Clutches on a Dual Clutch, so everything needs to be unworn. If you do have to change the Clutch, you will need to set-up the Levers and the PTO Clearance on the new Clutch, DON'T fit it straight from the box, this applies to any Clutch on any tractor, you cannot be sure that the setting is correct for your Tractor. To Adjust the Clutch Levers on your present Clutch you will need to use a NEW Clutch Plate even if the old Plate appears to be comparatively unworn. If any Plate has been used there will be some wear, so you need to use a NEW plate to re-set the Levers even if you use the old Plate when you rebuild the tractor. As I said earlier there is very little movement on a Dual Clutch, so it needs to be set correctly or you will have problems and you can't set a Dual Clutch without using a new Plate. Don't be tempted to try it with the old Plate or you could regret the decision. John(UK)...fergusontractors@hotmail.com |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
