Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Couple of questions about TE20
09-29-2012 09:48:59
The gaskets between the diff housing and the Rear Axle Housings need to be the correct ones if you use thicker or thinner ones this alters the float in the Diff. You shouldn't use any sealer, there is no need and if you do, in effect you are using a thicker gasket which will give more free-play. The studs that you need are not listed now, the thread will cause the problems as it is 7/16" x unc one end and UNF the other...John(UK)
