Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: TO35 Starter Problem
Bob Mc
09-27-2012 17:12:12
I found the problem. After I removed the starter and could turn the armature by hand I applied power to the starter and it ran. I could get it to run then it would stop, sometimes it just sparked and drew a lot of current, then it would run. I noticed sparking coming from the commutator and brushes. The brushes are worn to the point the brush retaining screw heads are rubbing on the commutator. The commutator is worn so bad the segments are even with the mica insulators. I was going to replace the brushes until I saw how bad the commutator was worn. I guess I'll just get another starter. This was the stock 6 volt starter, am I correct in assuming the 6 volt replacement starter from YT will still work with my 12 volt system? Thanks for the replies and help.
Bob Mc
09-28-2012 06:07:13
 Re: TO35 Starter Problem in reply to Bob Mc, 09-27-2012 17:12:12
You shouldn't use a 6 volt starter on a 12 volt system and expect it not to give problems or last a long time. We do use a 6v Starter on a TO20&30 but that is only because there isn't an alternative.If it has a 6 volt starter but it has a 12 volt battery, has the tractor been converted to 12 volts together with the ancillaries. The Ground Lead should be attached to one of the bolts close to the Starter to give the best possible connection. The tractors were changed to 12 volts from serial number 161350.
