| Harry Ferguson Tractors Discussion Forum |
Topic: Re: 1950 Ferguson TO20 has no spark
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Rickoff
09-26-2012 17:54:26
166.182.80.68
Problem solved! As I suspected, it was the toggle switch that the previous owner had substituted for an ignition switch when the old key switch went bad. It had worked fine, and was beefy enough that after ohm meter tests showed the switch was functioning properly (with an open circuit when off, and zero ohms when on) I was not all that suspicious until after I had double checked everything else. I knew that something was obviously robbing amperage, so first thing I did this morning was to disconnect the negative cable end from the battery, and connected my digital multimeter to see if any current was flowing between the cable and the battery post. There should be NO current flowing when the ignition switch is off and no devices are in use. Sure enough, this test showed a draw of 5 amperes. I removed the ignition switch and its wires from the circuit, reconnected the battery terminal,and then ran a wire directly to the coil negative terminal from the Load connector of the voltage regulator, thus bypassing the switch altogether. The wire end, as it touched against the coil's negative terminal, gave off a visible arc, so I knew the switch had been the culprit. Sure enough, the engine started up immediately when I turned gas flow on and engaged the starter. Later on I went to the local auto parts store and purchased a well built key switch that I installed upon returning home. Also purchased a new toggle switch for lights, as I'd like to have some running lights this winter when plowing snow at night. The previous owner had removed and saved one of the old headlights, and one rear lamp. I haven't tested them yet to see if they are any good, but would like to have a pair both front and rear, so will be looking to see what I can find. Any suggestions on a source for original lamp fixtures? If so, thanks in advance.By the way, that defective toggle switch was marked rated at 30 amps, which would seem more than adequate, but was definitely not the original light switch as it is marked "Made in China." Nearly all electrical components sold in auto parts stores nowadays are cheaply manufactured in China. Sad, but true. |
| DON TX
09-28-2012 21:57:06
76.196.6.124
Re: 1950 Ferguson TO20 has no spark in reply to Rickoff, 09-26-2012 17:54:26
| Glad you found the prob. Electrical probs are the hardest for me to find sometimes. DON TX |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
