| Harry Ferguson Tractors Discussion Forum |
Topic: Re: 1950 Ferguson TO20 has no spark
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| 2tractors
09-26-2012 05:08:29
207.144.5.133
If your getting fire to the coil that eliminates the switch,leaving the insulator to the distributor being shorted or either the condensor connector is touching ground.Is it a+ grd. or-? |
| Rickoff
09-26-2012 16:25:44
166.182.80.68
Re: 1950 Ferguson TO20 has no spark in reply to 2tractors, 09-26-2012 05:08:29
| @2tractors: As stated in the first sentence of my original post, this is a 6 volt positive ground system. I also stated that the coil tower was not throwing a spark with the high voltage wire placed near the engine block, so no way that the ignition switch can be "eliminated." I did state that there was 6.3 volts present at the coil primary terminals and the distributor connector with the points open, but since voltage is constant in this type of circuitry (other than what should come out of the coil, which is a voltage step-up transformer) the indication of correct voltage being present at the coil and distributor does not mean very much, since you can have 6.3 volts but very little amperage present if there is a partial or full short somewhere in the system that is robbing amperage. As you suggested, the distributor connector insulation could be cracked, and thus robbing amps by partially or fully arcing to ground whenever the voltage rises in the coil's primary windings. Although I hadn't mentioned it in my first post, I had checked the insulator when checking all the tractor wiring for any possible grounds. Thanks for offering suggestions, though. |
| 2tractors
09-27-2012 05:49:29
207.144.5.133
Re: 1950 Ferguson TO20 has no spark in reply to Rickoff, 09-26-2012 16:25:44
| My bad on not remembering your mentioning the 6V system at the beginning but in my defense it was a long post BUT there seems to be a flaw in your remedy of finding an amperage draw with the toggle switch which you stated checked out at ZERO ohms when on. An if there was a draw your cables would heat up and drain your battery. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
