This TE 20 I'm working on for a friend, had the original hood that had a cut out for the gas fill and radiator fill. It was sitting on the rad not bolted/clamped front or back. The rad must not be original since it sticks up at least 2" above the hood or was modified for some reason. The oem rad seems to measure same as the ones sold here as oem. I'd like to see a pic of an oem if anyone has one. I bought a hood for a 30 that is supposed to fit a 20 but it seems to be @ an inch longer and is about 2"s higher from front bolts lining up. I'm considering fabbing a bracket to attach the front to. Any other Ideas? The oem hood is so flimsy from cracks and metal fatigue I'd rather not use it and it's missing the grill. TIA
DON TX
DON TX
