Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: pto not engaging
greg elsenrath
09-20-2012 08:38:54
Do I have to drain oil to inspect the pto lever is engaging?? The lift arms go up and down so I thought the lever was engaging properly or is there a seperate operation for the lift arms versua the pto shaft??
Jerry/MT
09-20-2012 11:21:46
 Re: pto not engaging in reply to greg elsenrath, 09-20-2012 08:38:54
Check you ORC and make sure that its functioning properly. If you lift arms are working, the front half of the pto shaft is engaged in the pump and turning. If the external part of pto shaft isn"t turning either the ORC is damaged and slipping or the shaft is broken aft of the pump. Pull the right hand side plate off and look unless you find it"s the ORC.
Copyright © 1997-2015 Yesterday's Tractor Co.
