Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: TO 35 Govenor
[Return to Forum]
StvRkh
09-19-2012 16:33:07
66.87.90.4
Recently bought a really sharp TO 35. Has Govenor issues. Kinda works but very sluggish. One problem is I'm missing Compensating spring link. No longer available. Does any one out there have one I mite buy? Also does anyone have a clear directions on how to adjust this linkage when I find one? To nice a Machine not to run properly. Any help would be really appreciated.
[Reply]   [No Email]
JPFL
09-21-2012 11:10:47
173.65.222.172
 Re: TO 35 Govenor in reply to StvRkh, 09-19-2012 16:33:07
Stv, call me back, I have the part I think you are looking for. Jim in FL 813---------
[Reply]  [No Email]
John(UK)
09-20-2012 04:36:30
79.76.253.110
 Re: TO 35 Governor in reply to StvRkh, 09-19-2012 16:33:07
The governor will never work unless the compensating spring and link is fitted. Both springs must be in good condition and not stretched or rusted or they will be weak, same applies to the one on the vertical rod, they are available. Governor will not operate correctly if there is anything wrong with the springs.
This could be part of the cause of sluggish operation, but the usual error is the Bumper Spring has been adjusted incorrectly and too much pressure has been applied.I have the dimensions of the Compensating link and the information about how to adjust the Governor correctly. Because the Governor is not operating correctly, never presume that it is the Governor, it is almost always adjustment of the linkage, no matter what tractor model you have.
When you took off the Timing Cover did you replace the oil seal and gasket as they often leak when they have been disturbed. If you need the setting information for the Governor and the compensating spring link, email me direct and I will send it to you....John(UK)...fergusontractors@hotmail.com
[Reply]  [No Email]
StvRkh
09-19-2012 20:17:23
66.87.88.213
Had Timing Cover off an all internal Govenor parts looked ecellent.
[Reply]  [No Email]
Charles in Aus.
09-19-2012 19:57:18
211.30.56.106
Poor Governor response is often caused by worn Governor weights and 'mushroom' found behind the timing chain cover
[Reply]  [No Email]
Inno
09-19-2012 19:00:52
65.95.123.154
You may well be right. On my 202 the hand throttle has little indents which hold it in place, not sure if that was original or not, doesn't look like it. On the TO-35 it uses the friction plate etc. that is supposed to hold the lever in place and perhaps the comp. spring plays a part in that.
[Reply]  [No Email]
John(UK)
09-20-2012 04:42:44
79.76.253.110
 Re: TO 35 Governor in reply to Inno, 09-19-2012 19:00:52
The throttle notched plate is standard on this tractor and it will still have the friction Disc. They used both because of the vibration on these industrial tractors and they needed to be fixed with little chance of them closing down as often the tractor was left to run unattended or the operator was perched up on a Rear Digger and couldn't reach the throttle easily.The compensating spring is aways fitted as it is part of he Governor linkage on a gas engine..John(UK)
[Reply]  [No Email]
ken52m
09-19-2012 18:22:30
97.91.68.215
I hesitate to jump in here but I think I know this one... The only purpose of the comp. spring & link is to balance forces w/ the governor control spring so that the throttle lever will stay put where you set it. i.e. w/o the comp spring the throttle lever would return to idle pos. when you release it. The comp. spring does not affect the function of the gov. Only the throttle. Hope I don't get beat up to badly on this one.
[Reply]  [No Email]
Inno
09-19-2012 17:20:05
65.95.123.154
John UK has instructions on how to set up the governor. I'm not sure if it is correct but my compensation spring on my 202 (same engine) was missing and I just used one I had around the shop. I'm not sure the exact function of it or how important it is. Once I adjusted as per John's instructions it seemed to work pretty well.
Just bought a TO-35 last weekend and it needs some governor work too.
One of the biggest things is making sure that everything operates easily and smoothly (no binding) and there is minimal wear of all the moving parts. It needs to be tight but loose if that makes sense.
If I find the instructions before John comes on I will try to post them. For some reason I haven't been able to find them. They might be on a memory stick I took to work.
This post was edited by Inno at 17:22:46 09/19/12.
[Reply]  [No Email]
JPFL
09-19-2012 16:50:59
173.65.222.172
Do you know if one from a TO20 or 30 will interchange?? I have those . Jim 813+--------
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
