Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: TE 20 steering wheel
samn40
09-16-2012 16:39:53
Fit the tank into a cement mixer padded well with old blankets or foam or what ever and put a length of chain inside to loosen the rust. the chain is easy to fish out again. Repair pin holes with fibreglass resin painted on the outside. it works a treat. Mine has been 'repaired' this way since 1985 and is still good. Te 20 steering wheel should have steel spokes and a single keyway. use a 3 leg puller to remove. Sam
DON TX
09-17-2012 14:19:28
 Re: TE 20 steering wheel in reply to samn40, 09-16-2012 16:39:53
The tank has a divider in it that will not let a links very big get in. That's 1 reason I'm trying to get it chemically clean. I don't feel cleaning half the tank will be enuff. There is a small opening along the sides of the divider and will be a real pain to get chain, bb,s, gravel, etc. in or out. N's have many more openings to allow larger objects to escape when needed. I haven't tried to put the puller on the wheel yet, but wasn't sure if I have room between the wheel and the cover under it. Don't want to mess the cover up.
Thanks,
DON TX
